shoebox thanks but
Old Oct 8, 2004 | 06:03 PM
Zeueses 97 RamAir's Avatar
shoebox thanks but
Hey shoebox thanks for all your help on the bcm prob on my car, it is the bcm I wiggled it tapped on it and it turned the radio on and off. So its the bcm unplugged it and evrything still turns on and off when driving ,radio. Now when buying a new bcm on a 97 trans-am do you just plug it in and leave your key on for 10 min. the guy at the draler told me you plug it in so it can learn the key resistance for about 10 12 min. Just to make sure is that all you have to do... Thanks again for all you help...... ps OH I know earlier models you have to reprogram thats why im asking....
Old Oct 8, 2004 | 06:35 PM
Re: shoebox thanks but
A brand new BCM will program itself when you turn the key ON for the first time. It can only do this once for the life of the BCM and it will be programmed to accept the key pellet resistance of the key that was used. Turn the key to ON and then start the engine. The security lamp should go out in about 5 seconds, indicating that the BCM is now programmed. If you get a flashing security lamp, the BCM is not programmed and probably not reading the key.
KYWes
Jun 14, 2022 06:52 AM
gelbza
Jul 12, 2015 08:10 AM
mrz28M6
May 16, 2003 04:24 PM
rmackintosh
Mar 18, 2003 05:20 PM
Coop1
Feb 27, 2003 08:10 PM
