Do I really need a new timing chain?
Re: Do I really need a new timing chain?
Should I just replace them with stock replacements or do I need the "LT4 Extreme Duty" timing chain?
My car's coming up on 100k miles, by the way.
You can get away with stock peices, but check for chain tightness, if it is looser then you can move up to a larger crank sprocket to tighten the chain up. If you have the money the LT4 chain is nice.
Originally Posted by Euclid
Doing a heads cam swap, do I REALLY need to replace the timing chain?
I was about to do a cam install and was thinking the same thing. Electric waterpump and cloyes double roller. You just used a standard SBC setup right? I just cant see paying $300 for a timing chain when I could get a electric pump and gain a few horses and take less strain off the cam/berrings and get a good double roller for less money than an "extreme timing chain"
Oh what brand and where to buy a electric water pump for $135? The ones I've priced were around $160-$180
Thats the way to go.
Cloyes can direct you.
Here's their catalog, They have some oversized sets about mid way through.
http://www.cloyes.com/images/CloyesH...rmCat-2002.pdf
