LS1 28.8lb injectors suitable for stock headed CC306?
Old Oct 10, 2004 | 02:57 AM
BlackLT1_TX's Avatar
Just like what it says!
Old Oct 10, 2004 | 04:21 AM
Zeueses 97 RamAir's Avatar
Re: LS1 28.8lb injectors suitable for stock headed CC306?
thats more than enough get fuel pump with that setup,,,, youll be fine get a tune also
Old Oct 10, 2004 | 08:14 AM
simple's Avatar
FYI, the LS1 injectors are rated 28.8lbs at a fuel pressure that is higher then 50psi, the LT1 being rated at 43.5psi will actually lower the rating of the LS1 injector down to stock LT1 injector ratings
it would be a waste of money (unless yours are bad) to buy these injectors IMO
try searching this you will find alot more info on it
Old Oct 10, 2004 | 11:09 AM
Z95m6's Avatar
Ditto. I think you would be pushing those injectors to the max with that cam.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
