Heater core hose install?
Old Oct 8, 2004 | 09:27 PM
Red95M6Z28's Avatar
The plastic part on the heater core hose broke and I would like to change it. Is it a difficult process? Is there a write up about it somewhere? Thanks!
Old Oct 9, 2004 | 07:25 PM
S8ER95Z's Avatar
Re: Heater core hose install?
I just had to do this... I removed th 3 bolts holding in my glove box and removd it. Then there is ~5 lil bolts I think holding the heater core housing together. There is 1 bolt holding the outsite of the heater core down under the hood (right where the hoses connect to the heater core at the firewall).
remove those 2 hoses, the glovebox and the bols from the heater compartment. Pull the plastic off after unbolting it and you will see the heater core. It takes a little finesse to slide the heater core out but it does come out rather easily.
I spent an hour and half (including a quick trip to Autozone to get a new one). Hope that helps.
Its not really that difficult and I was suprised at how easy it was.
Old Oct 9, 2004 | 09:04 PM
Hyperspeed97z28's Avatar
WOW,
You make it sound as if it were rather EASY, I might just go do mine tommorow now... hehe
Old Oct 9, 2004 | 11:19 PM
Spinner's Avatar
That about it. Took me about 90 minutes too, $65 lifetime warranty core from autozone.
Old Oct 10, 2004 | 10:37 AM
S8ER95Z's Avatar
Seriously after hearing horror stories from Ford Taurus cars and various other cars..I was not please that mine broke.. when I saw coolant on the carpet the day I started my car for the first time I was pissed... however as soon as I started in on it.. it was really easy and I wasnt as mad anymore.
Old Oct 10, 2004 | 12:47 PM
Red95M6Z28's Avatar
Thanks so much for the help guys. But, what I was looking for was the hose that runs from the front of the motor back to the heater core. Thats what broke and needs to be replaced. Any ideas there?
Old Oct 10, 2004 | 06:33 PM
S8ER95Z's Avatar
Hmm..have you checked Shoboxs page for part numbers?
Old Oct 10, 2004 | 07:01 PM
Spinner's Avatar
Do a search. This came up pretty recently.
Old Oct 10, 2004 | 07:22 PM
Red95M6Z28's Avatar
I knew someone would say that. I actually did a search already and came up with heater core replacement but thats not what I need. I need the hose that goes back to the heater core.
Old Oct 10, 2004 | 08:00 PM
Spinner's Avatar
I couldnt find it either. I'll post up the pns for you in a bit, gotta go somewhere atm
Old Oct 10, 2004 | 08:04 PM
Mtrhds94Z's Avatar
Number 13 here on shoebox diagram?:
http://shbox.com/1/heater_hoses.jpg
GM 10188036 [about 8 bux or so from Cromer etc] is the only 'plastic thing' I recall..
It's a 'flow restrictor valve' in the heater hose that's plastic?
You can cut the aluminum crimped clamps off with a Dremel [cut gently thru it and then put a screwdriver into the slot and split it off there]
Then replace that restrictor, and use 2 regular screw type heater hose clamps..
Old Oct 11, 2004 | 12:38 AM
Spinner's Avatar
^ all the part #s are on there. Good luck
Old Oct 19, 2004 | 02:23 AM
WickdZ's Avatar
Is that flow restrictor a required part?
My 95 TA (just bought in July) has the heater core bypassed. Since it is starting to get cold out, I went ahead and replaced it (easy to do). I did not want to take a chance of it having a leak after I flushed the system.
The guy I bought the car from just used some splices and made the heater hose loop around and put the bleeder valve on top. Hard to explain, but I want to put it back to stock so I can have some heat this winter.
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
kksi
Feb 17, 2015 10:41 PM
Britbilly
Jan 7, 2015 08:49 PM
Black93lt1
Nov 21, 2014 07:30 PM
