ignition fuse blowing
Old Oct 7, 2004 | 12:54 PM
CatsTasteGood's Avatar
my car: 97z28, m6, heads and cam, headers, electric wp.
the ignition fuse keeps blowing. i checked all the wireing to cps, coil, and icm. i dont think it is the ignition switch because my fuel pump still turns on. if i replace the fuse the car will run for a 10-30 seconds then itll shut off. i still have the lights on my dash when it blows. it seems it will blow faster if i try to move the car rather than let it idle.
Anyone have any other ideas for what i can check?
Old Oct 7, 2004 | 12:58 PM
IllusionalTA's Avatar
Re: ignition fuse blowing
I had this problem once!.. NOt sure what i did to fix it.. I"m thinking my water pump wiring was to blame? not sure..
Old Oct 7, 2004 | 01:02 PM
ive heard of people having this problem with an electric wp, but it seems they were running the wiring off of something else. my wp has its own relay, fuse, etc.
Old Oct 7, 2004 | 01:04 PM
Yes i understand about the relay and its own fuse.. but wheres it getting its IGN HOT! from? when you turn the key on its pulling its 12V From a IGN ON 12V Source such as that in the Fuse block under the hood..
Old Oct 7, 2004 | 02:54 PM
right right...i didnt think of that. i think it may have been the wp then. i inspected all the wiring for that and i think the power wire for that my have been shorting out. i resituated and reinsulated everything and i havent blown the fuse again. ive run into alot of little problems since i started modifying this car and no matter what my girlfriend says, its all worth it.
Old Oct 7, 2004 | 03:14 PM
Tada!
Old Oct 9, 2004 | 01:44 PM
TTT
it seams it was not the water pump wiring. it is still doing it. if i just let it idle it will idle for a while but if i rev it alot of try to move it will blow. when i rev it the lights on the dash flicker. ive checked all the wiring to all the stereo stuff and gauges i added just in case they were doing it and they are fine. any other ideas on what to check?
Old Oct 10, 2004 | 06:37 PM
ttt anyone have an idea of something to check?
Old Oct 10, 2004 | 06:51 PM
Dave69Z's Avatar
Check all your grounds. Make sure the 3 grounds under the nut on the bolt holding the coil are in place and make sure the nut is tight if they are all in place.
Dave
Aug 18, 2015 07:08 AM
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RUNMYTA
Jul 15, 2015 07:50 PM
