Shavings in oil (very small amount) - normal?
I changed my oil today. When I let the oil pour down on my finger, I could see a few (2 or so) tiny little metal specs. I made sure my finger was clean and repeated this several times. My motor has 86,300 miles on it, doesn't consume oil, and pulls hard in every gear until redline.
I know it's not normal for the oil to look like glitter, but is it normal to have just a few tiny specs? I'm assuming it's normal wear?
Matt
Matt
Re: Shavings in oil (very small amount) - normal?
I use a magnetic drain plug and pick up a bit of 'fuzz/grey paste' looking stuff[ very little it barely coats the magnet..]on most vehicles I have used them on.. I consider it normal..
How did you hold your fingers under that hot oil?[ you should drain it hot..]
Th bunker..I wasn't aware that bearings were magnetic?[journals on main/crank/rods yes but not the bearings themselves..
Originally Posted by Cmr0z28
..and how might I do that?
Originally Posted by Z28SORR
I think he's talking ball and roller bearings, not main and rod.
there aren't any?..[maybe roller rockers if you got those]
Do you mean there's a ball/roller bearing in the block for the water pump drive gear?[never had mine out?] I always thought that was a 'bushing' arrangement..
If so, I stand corrected..
If you mean in the water pump itself.. well the alternator and starter have bearings, too[ and some pilot bearings in M6's] but that can't get into the motor oil...]
Yes it is press fitted into the block. Picture of the back half.
http://ken.lowrance.com/projects/CSI...PumpShaft2.jpg
From side..
http://ken.lowrance.com/projects/CSI...PumpShaft1.jpg
From side..
