Header leak or Valvetrain noise ?
Old Oct 11, 2004 | 03:54 AM
Blue_SS's Avatar
Question Header leak or Valvetrain noise ?
Ever since I put my headers on I have a strange noise coming from what I would guess the front on the engine... I cannot tell for sure its caused by an exhaust leak, because when I installed my headers I also for the first time put in the borla block off plate. That decreased exhaust sound a lot, and so I might hear things that I didn't hear before.
In idle everything is fine, I can just hear it when I start accelerating, its a kind of tick tick tick noise (sounds a bit like a metal rattle, though its a higher pitched sound). It goes away as soon as I let of the gas pedal.
After the install of the headers I had everthing checked by a mechanic and he said there is no leak anywhere... what do you think it is ? Maybe something in the Valvetrain ? Maybe just engine noise amplified through the headers ?
Thanks,
Alex
Old Oct 12, 2004 | 01:37 AM
Blue_SS's Avatar
Re: Header leak or Valvetrain noise ?
Has nobody experienced similar noise ?
Old Oct 12, 2004 | 05:30 AM
sssalah's Avatar
Its your headers leaking probably, has this sound appeared as soon as you installed the headers? or has it slowly increased as you used the car after the header install. have you retighten the header bolts.
Old Oct 12, 2004 | 05:48 AM
Blue_SS's Avatar
I had noticed that noise as soon as I had the headers installed... the mechanic however checked for leaks and couldn'T find anything... so either it's not not a leak or he's trying to screw me....
Old Oct 12, 2004 | 09:07 AM
TransAmGT94's Avatar
I would have to guess header leak also
Old Oct 12, 2004 | 09:50 AM
WS Sick's Avatar
Almost completely positive it's an exhaust leak.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
BigWil
Mar 29, 2015 12:24 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
