Opti problems?
Old 10-06-2004, 07:35 PM
Bad64chevelle's Avatar
Opti problems?
My car has a bad sputtering/ surging problem. It surges at idle, and sputters till 2,000 RPM's also sputters around 4800-5200 RPMs also. 02's,plugs,wires,fuel filter,air filter have ALL been changed along with gutting the cat. Other than the problems stated the thing runs EXCELLENT Could this be my Opti, its been progressively getting worse i have disconnected the EGR vacuum supply and nothing happened..same old crap. I plan on purchasing an opti unless people suggest otherwise. Where is the best place to get one that has a good price? Thanks!
Bad64chevelle is offline
Old 10-06-2004, 07:36 PM
ChrisS95TA's Avatar
Re: Opti problems?
I had the exact same symptoms, did opti along with what you did besides and now I am running GREAT to 5300 on tach, not sure what actually is.
ChrisS95TA is offline
Old 10-06-2004, 07:37 PM
Re: Opti problems?
Opti fixed it? whered ya get it from? how much do they run?
Old 10-06-2004, 07:44 PM
ChrisS95TA's Avatar
Re: Opti problems?
http://www.billygrahamscamaro.com sells em cheap
Also call http://www.samtaylor.com/html/parts.html Jason I think at Sam taylor he is as cheap as you can find one.
I would have a hard time getting going, once it do though through our powerband it ran good so I had no problem merging or whatever but I never went over 4500 because of the problem. Also was slow getting off the line, had to baby it with the clutch
10-31-2016 11:09 AM
greenzee28
03-26-2015 09:13 AM
grabbem88
03-18-2015 01:25 PM
Alex Barnes
01-24-2015 10:21 PM
Injuneer
12-15-2014 09:36 AM
Quick Reply: Opti problems?
