Quick pushrod and rocker question
Old Oct 7, 2004 | 10:23 AM
25th_Trans's Avatar
Question Quick pushrod and rocker question
You can here a clicking noise a little with the hood up on the drivers side, but with the hood down you can't hear it. Does this sound more like I need to do another valve adj or could it still be a bent pushrod? Also, would it be better to adjust the valves with the engine warmed up or cold?
I can also see marks on the top/inside of the valve cover where it looks like the nut from the roller rockers are hitting the valve cover. I put the correct preload on them. I have the GMPP 1.6rr w/ poly locks, stock length hardened pushrods, LT4 valvesprings, and the LT4 hotcam. Did anyone have to replace there valve covers b/c of this problem? I thought that with this setup you could keep the stock valve covers.
Old Oct 7, 2004 | 11:52 AM
LT1ZZZ's Avatar
Re: Quick pushrod and rocker question
I have the same valvetrain setup on a stroker and run the stock valve covers, i had to modify mine but i have guide plates but they were not hitting on the top of valve covers.By the way roller rockers are a little noiser ya know,and if you had a bent push rod you would know it.I can also hear roller rockers a little but am told it is normal.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
armedtrigger
Feb 24, 2015 08:30 PM
Roadie
Feb 16, 2015 10:34 AM
