Help with DTCs: 26, 77 and 83
Old Oct 9, 2004 | 08:02 PM
sideways_Into_3rd's Avatar
26 is CCP fail, carbon canister purge I assume ?
77 is Fan 1 fail
83 is Reverse inhibit solenoid fail
All of these codes showed up at once and car started to run like anus (which i think may be a burnt wire)
any can see why these 3 codes would appear altogher ? any correlation ? anyone seen any of these before or dealt with them ?
Old Oct 9, 2004 | 08:24 PM
Re: Help with DTCs: 26, 77 and 83
They are all on the same fuse. Your O2 heaters would be out, too. Check fuse #6 under the hood.
Old Oct 9, 2004 | 08:34 PM
You are god
I'll go check on that right away
could the O2 heater thing be related to the fact that i was running around with the biggest exhaust leak from my headers for a month (missing 3 bolts in teh back )
should i look into getting new O2s ?
Old Oct 9, 2004 | 08:44 PM
The fact that you had an exhaust leak should not affect the heating circuit. A burned wire on the headers is a common cause of this fuse getting blown.
Old Oct 9, 2004 | 08:49 PM
makes sense .. voltage going throuh a spark wire is a tad over 12V
i'll look into the fuse the the wire asap
but the O2 is ok you say
Old Oct 9, 2004 | 10:58 PM
I was referring to a burned wire to the O2 sensor-just to clarify. If it is on the sensor side of the connector, it would be better to replace the sensor.
Old Oct 9, 2004 | 10:59 PM
hmm .. i thought u mean the spark from the burnt plug wire is jumping on the header and going through to the O2 heater causing the fuse to blow
Old Oct 9, 2004 | 11:03 PM
No, but that is very creative thinking.
