3.42r boom 3.23 now got a cc306 t56
Old Oct 10, 2004 | 09:14 AM
Formula305fi's Avatar
Exclamation 3.42r boom 3.23 now got a cc306 t56
Well here is my situation, my 3.42 rear is toast. I had a car accedent it a curb bent the axle drove around like that for 3months till i could afford to fix it.. make a story short the housing is Fk'd. I got a 3.23 complete rear going in now.. But i also bought a cc306 cam kit from cmotorsports, am I going to have a really hard time now. My car is a t56 so I dont think it would be to bad. I dont have any intesions on redoing the 3.23s for quite sometime now.. All help would be gr8... Cam suggestions anything....
Old Oct 10, 2004 | 09:47 AM
Josh-'04 GTO's Avatar
Re: 3.42r boom 3.23 now got a cc306 t56
Your car will run fine. Would the CC306 prefer a steeper gear than 3.23? Yep. But you can definitely run that cam kit and then upgrade your gears when you have the time and/or money.
Old Oct 10, 2004 | 09:50 AM
Oh.. Thought I would have alot of cam surge, heard these cams surge alot in low rpms... I dont have any experience with it yet... THe cam dont go in for a couple weeks, but the rear is going in tomorrow.. With the 3.23s will i be able to keep up with say a 224/230 car with 4.10s?
Old Oct 10, 2004 | 10:34 AM
S8ER95Z's Avatar
I have 3:42s and an Auto.. I dont really feel it unless im under 1500rpm and trying to accelerate slowly. With a manual you can just shift if you feel it.
Old Oct 10, 2004 | 10:38 AM
Dam and im sitting here all worried, Thanx guys... Cleared my head of that mess.... Also I have a hotcam, just wondering if I am better off using the hotcam or cc306, what ya's think??? Im only doing the cam swap once, rear fix once unless it breaks again....
Old Oct 10, 2004 | 11:38 AM
DuronClocker's Avatar
Do the CC306. It'll be fine. You'll end up getting more out of that cam than you will the hot cam..
Old Oct 10, 2004 | 11:45 AM
Okie dokie guys thanx, hope ill be able to spin in 2nd still.
Old Oct 10, 2004 | 03:56 PM
Fastbird93's Avatar
I'll just chime in here seeing as how I have a hotcam (with heads) and T-56 setup on a 3.23 rear.
You're going to want gears. Bad with the 306. I'm crossing the traps i third gear @ 6200 RPM with my setup. The hotcam isn't know to be a slouch down low either, but it's downright doggish on my car because of the gearing.
Old Oct 10, 2004 | 04:35 PM
ugh. i dont have plains on changing my rear gears again for quite awhile.. esp since i wont have any money left after my cam swap. lol... so should i go hotcam route or cc306 route with the 3.23s... Guys IM me: Dazed1969 is m AIM name...
Old Oct 10, 2004 | 05:19 PM
The hotcam will be more "streetable", meaning more low end torque and all around driveability. However, the CC306 will make more top end and have more loping/surging at the low end. It all depends on your priorities...
Old Oct 10, 2004 | 05:24 PM
my priorities ly in being about to daily driver her, for she is my daily driver...
Old Oct 10, 2004 | 05:40 PM
Fastbird93's Avatar
You'll probably want to stick with the hotcam then.
Old Oct 10, 2004 | 05:43 PM
Alright thanx for the help guys. 1.7rrs with the hotcam should be pretty good
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Boss002
Jul 9, 2015 03:33 PM
