Any suggestions on making a custom steam pipe?
Old Mar 2, 2005 | 01:12 PM
Pasky's Avatar
Just called both GM dealers here in town and the damn thing is marked up 300% at $75.68. I have the bolts and the seals, what im missing is the pipe, it kinked last night when I was doing valve springs and broke in half. Anyone know how I could make a custom one and who or what chain store in town might carry stainless steel hose so I can make one thats flexible and more pleasing to the eye?
I am well aware of gmpartsdirect however I want my engine in the car this weekend, so kind of in a hurry.
Thanks.
Old Mar 2, 2005 | 01:19 PM
1-bad-z28's Avatar
Re: Any suggestions on making a custom steam pipe?
I don't know about anykind of flexible hose you could use but a brake line might work.
Old Mar 2, 2005 | 01:28 PM
Cut out the kink and clamp some rubber hose on it. How's that for a cheap fix? It wouldn't be my favorite thing to do, but others have spliced out the pipe.
Old Mar 2, 2005 | 01:34 PM
Pasky's Avatar
Well, im not looking for cheap, but I suppose that will work until I can purchase a new one at a much cheaper price since time won't be an issue then.
Old Mar 2, 2005 | 01:37 PM
Jameslt1TA's Avatar
Hey pasky ive got the egr steam pipe off of my engine...ill sell it you ya for 15 bucks shipped...just pm me
Old Mar 2, 2005 | 02:56 PM
Pasky's Avatar
EGR? Don't believe this is part of the egr.
Old Mar 2, 2005 | 05:20 PM
It's not. I think that was an oops.
Old Mar 2, 2005 | 06:49 PM
SStrokerAce's Avatar
I always make them with braided lines and AN fittings after I cut the pipe off the parts that bolt to the back of the head with banjo bolts.
Bret
Old Mar 2, 2005 | 06:55 PM
indieaz's Avatar
The first time i removed my heads during a cam swap i broke the pipe - repalced it for $70. When i rebuilt the engine and removed the pipe i lost one of the bolts - you can't buy the bolt individually apparently so i paid another $70...just for the bolt (my steam pipe was virtually new). I assembled the engine and found the bolt several weeks later (it rolled off my porch into the grass somehow). :-( I feel your pain.
Old Mar 2, 2005 | 07:05 PM
Pasky's Avatar
I have no clue where to find AN fittings and braided steel lines in town. Any chain stores carry them?
Old Mar 2, 2005 | 07:52 PM
97WS6SCharged's Avatar
Any hot rod shop should carry them. If nothing else, there's always the board vendors. FYI, it won't be cheap to build a new pipe out of AN fittings and braided hose. Mine cost me right around $80 bucks though it is alot easier to install than the old steam pipe.
Old Mar 2, 2005 | 08:19 PM
Pasky's Avatar
Well I know the fittings are about $15 bucks a pop and the steel hose for what? 3 feet, should be about another 20. At least it will look nice, if anything i'll use heater hose and get a stock replacement from jason.
Old Mar 2, 2005 | 09:05 PM
Most of them are $5-6/ea, the only ones that are $15 are the bent hose connectors. I believe the hose itelf is like $6 a foot or something.
Old Mar 2, 2005 | 09:17 PM
The bolts are available separately.
Old Mar 2, 2005 | 11:27 PM
indieaz's Avatar
Well I figured they must be and assumed the guys at the dealer were morons and don't know how to look up a part. Turns out I am right.
