Is this cam surge?
Old Mar 7, 2005 | 02:21 PM
Jameslt1TA's Avatar
Is this cam surge?
Hey guys ive got my car back up and running but i still dont have a tune yet. The car runs good for about 5-10 minutes and then it starts bucking and misfiring...i turn the car off for about 10 seconds and turn it back on and it will run fine and smooth for another 5-10 minutes. Will a tune fix this or not?
thanks
james
Old Mar 7, 2005 | 03:00 PM
OBE1 95Z28's Avatar
Re: Is this cam surge?
Cam surge is when you're in first gear at idel and the car wants to buck instead of moving at a steady pace. Not sure what your issue is...closed loop mod, using the O2 sensors as feedback, occurs after 2 minutes, not 5 - 10 minutes. Double check that all your sensors are connected (temp sensor in driver's side head, MAF sensor) and verify no intake leaks.
Old Mar 7, 2005 | 06:46 PM
Kreinmc's Avatar
I disagree, cam surge can happen in any gear and usually happens while cruising. Depending on how big the cam is you may have surging anywhere between 1000-2000rpms. Surging will most likely be the worst when cruising in parking lots at low rpms such as 1st gear at 5-10mph or on the freeway at low rpms.
Old Mar 7, 2005 | 07:27 PM
96ta(nick)'s Avatar
I have mild cam surge around 2k with my cc306. Your problem seems to be elsewhere but i will let someone else help you with it because i don't want to misslead you.
Old Mar 7, 2005 | 10:59 PM
Jameslt1TA's Avatar
lol it may be the o2s but im hoping my tune will fix it...i also think that my cable from akm will com with some data logging software and that should help me to pinpoint the problem. Its weird though if i just keep driving without shutting the car off the problem will eventually go away and then come back after another few minutes...maybe its not quite 5-10.
idunno
Old Mar 8, 2005 | 01:40 AM
disco192's Avatar
Cam surge happens when you are cruising at low throttle. I noticed cam surge in my cc306 when i was cruising about 1200 rpm at about 40 mph. Once I got the RPM up it stopped. It also didnt surge when I was cruising at 1200 on the highway with more throttle.
Doesnt sound like cam surge. You prolly have a tuning or sensor issue.
Old Mar 8, 2005 | 06:52 AM
med_reject's Avatar
idunno
that is your pcm switching back and forth from open to closed loop. You should see a check engine light when this is happening. Use a laptop to datalog the pcm output and check what the o2s are showing. That is most likely where your problem is. 1 or both of them need to be changed.
Old Mar 27, 2005 | 07:17 PM
KillerTA's Avatar
Is cam surge bad for your car? How annoying is it?
I like to drive at about 1500rpm so would a cc306 be a bad choice for me?
Old Mar 27, 2005 | 07:44 PM
slverbullet's Avatar
its annoying. but nothing you cant work around or deal with. if i start to get a little surge, i usually just give it a little more gas and cruise a little faster or just down shift.
Noenav
Mar 1, 2019 07:38 AM
AdsoYo
May 2, 2018 03:21 AM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
