Need some help please.
Old Mar 4, 2005 | 09:55 AM
ReaverZ28's Avatar
Oil in water, water in Oil 95z28. Its not the heads or head gasket they hold pressure. there is no leakage on the ground to suspect a cracked block. could it be in the "heat exchange"?
Old Mar 4, 2005 | 10:37 AM
Re: Need some help please.
The only other suspect would be an oil cooler if you have one. Gotta be that, heads/gaskets or block.
Did you do a leakdown test?
The head gaskets are the most likely suspect.
Old Mar 4, 2005 | 11:19 AM
ReaverZ28's Avatar
yes and it held. the oil cooler. im not sure my mechanic confused me. its the thing that takes water into the engine and cools the oil. so oil cooler i guess lol
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
navtool.com
Middle Atlantic
Sep 24, 2015 03:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
mlopezart
Sep 8, 2015 12:15 PM
