Need to Run 11.5x by July 1st!
Old Mar 2, 2005 | 05:12 PM
1quikZ's Avatar
Exclamation Need to Run 11.5x by July 1st!
Ok hears the story A buddy a work (ford dealership ) has a 1986 Mercury Capri. Everyone there thinks this car is frigin holy. It has a 347 Ford crate engine that puts out around 450Hp and with exhaust ect. It makes 495Hp on the dyno. The car is a wannabe 2000Gt with leather interior ect. The year before it ran 12.1 @ 108mph at the KOTHC. I would love nothing more that to beat this car at the king of the hill challenege this July. My sig is everything I got so far, I was thinking weight reduction first
By the way I have not yet done a 1/4 with my current setup so i dont know how close to my goal I am right now. I do not want to use NOS, Turbo Or supercharger as my catergory as well as his is naturally asspirated.
Thanks in advanced
Old Mar 2, 2005 | 05:24 PM
Spinner's Avatar
Re: Need to Run 11.5x by July 1st!
3.73 + 150 shot + tires
Old Mar 2, 2005 | 05:27 PM
soontobeGN's Avatar
Try a good set of heads to match that CC306, a 12 bolt rear with 3.73's or 4.10s, and a bigger stall with a set of ET Streets. That should put you right around where you wanna be. Also, are you sure his Capri is dynoing those numbers or is that at the flywheel?? Someone help me here as I am not quite sure, but if a Capri had 500 at the wheels, it should be below 12.1, or possibly 11.1 for that matter, they arent heavy cars.
Old Mar 2, 2005 | 05:48 PM
1quikZ's Avatar
No I am not sure I am just going by what I have been told. I know for a fact the engine makes 450HP (at the flywheel) its a ford crate engine. But the other specs I cannot confirm 100% I know the weight of the car if that helps its 3100Lbs.
We cannot use NOS in our catergory, and I have 3.73 Posi
Old Mar 2, 2005 | 06:15 PM
Raped Ape's Avatar
I'd start off by moving up the stall to around 3600 and getting some sticky tires.
Then I'd probably start dropping weight like BMR K-member, manual rack, !AC, etc.... Not sure where that would put you.
I'd also make sure the car is in good tune first by checking the fuel filter, plugs, wires, etc....
Old Mar 2, 2005 | 06:18 PM
Heatmaker's Avatar
Advanced Member
your not going anywhere near there on the 10bolt buddy...
NSA your only option is stroking.... 383-396
you pick you choose...
sometimes it's best to just let things be.... cause that's allot of money your talking.
soontobeGN's Avatar
Just spray it, noone would know!
J/K, if you know 11.5 will get you the win, thats very attainable as long as you got the cash.
Good luck whoopin' up on the Mustang wannabe
Old Mar 2, 2005 | 06:22 PM
396D1SS's Avatar
495 hp out of a 347 crate engine.... im not calling bs but that is VERY hard to reach with that crate motor with the heads it comes with. Have you seen dyno sheets of the run? have you seen it run at the track? unless he changed the heads/cam with that crate motor he is full of ****
Old Mar 2, 2005 | 06:25 PM
396D1SS's Avatar
You never know, I run low 10's on my 10 bolt :knock on wood:
Old Mar 2, 2005 | 06:28 PM
Heatmaker's Avatar
Advanced Member
THere's some guys taking it down low with the 10bolts... but for the average guy....
Old Mar 2, 2005 | 06:39 PM
1quikZ's Avatar
347cid 450HP
There is his engine.....
As far as weight reduction what about the back seat thats gotta be 100lbs,
what is a good set of track tires under $500?
Old Mar 2, 2005 | 06:47 PM
396D1SS's Avatar
how much money do you want to spend?
Also you said that guy ran a low 12 @ 108 mph . If he only traped 108 mph he does not have anywhere near 498 or 450 hp. All he has is a holeshot
Old Mar 2, 2005 | 06:57 PM
1quikZ's Avatar
Id like to keep it under 1k
Old Mar 2, 2005 | 07:04 PM
soontobeGN's Avatar
Sounds like this guy is figuring horsepower using Rice Mathmatics. Hmmm I got this crate motor that puts out 450....it said on my air filter box that thats giving me 10 extra horsepower....that exhaust is advertised to give me another 15 horsepower......still not even accounting for drivetrain loss either
I'm not sayin this guys car aint fast because with that motor that thing has to move a little, but 495 with no power adder....unlikely unless he replaced a few minor parts like heads and cam. I'm not sure about the ET, but 108 is pretty low for a 12.1 car.
Old Mar 2, 2005 | 07:05 PM
Spinner's Avatar
under 1k? roflcopter.
3.73, 150 shot, tires.
