Belts........
Old Mar 5, 2005 | 03:10 PM
JIMIZEE028's Avatar
Belts........
can I leave my air conditioning unit on my motor and when I want to use it run my stock belt,but when i want to run the car get a smaller belt bypassing the use of the unit?And if so would anyone happen to know what the size of the belt would be,and / or its part#????????
Old Mar 5, 2005 | 04:27 PM
RE AND CHERYL's Avatar
Re: Belts........
Won't work. Dosn't matter anyway. It dosn't draw any power off the motor. When the A/C is not running it's basically an idler pulley.
Old Mar 5, 2005 | 05:03 PM
MarkyMark's Avatar
Re: Belts........
Yea, the only true advantage of removing the AC is the weight loss off the front end of the car, and the extra space in the engine bay. I think with the AC on you get something like 5 to 10 percent performance loss if I remember correctly, but with it off it doesn't hurt you.
Old Mar 5, 2005 | 05:52 PM
tfs95z28's Avatar
Re: Belts........
I always thought that you would want your AC hooked up at the track so that when you are in line waiting to race, you can turn it on to cool off the engine better.
Old Mar 5, 2005 | 05:55 PM
slverbullet's Avatar
Re: Belts........
i thought you werent supposed to use your a/c at the track..?
as far as turning the fans on, you can get manual switches or a program to get them to come on earlier.
Old Mar 5, 2005 | 05:56 PM
tfs95z28's Avatar
Re: Belts........
only when waiting in line i have used it. NEVER when racing of course. It helps to cool off the motor, or maybe it is the heat that i turn on, either way you would need the AC hooked up to do that.
Old Mar 5, 2005 | 06:01 PM
GlueFactory's Avatar
Re: Belts........
You turn your heat on to help cool the motor. Turning the AC on actually makes the engine run hotter.
Joe.
Old Mar 5, 2005 | 06:50 PM
MarkyMark's Avatar
Re: Belts........
Only reason you here some people say they turn there AC on is to try and get the fans to kick on......get a manual fan switch and you wont have to do that at all. I frequently turn my heat on at the track, because I figure with the extra coolant running through the heater core, its gotta help cool your coolant a little bit.
