water pump weap whole question
Old Mar 1, 2005 | 10:09 PM
350pride's Avatar
I have a 94 Z28 and I noticed that my water pump was leaking from the weap whole. My question is if i get a meziere or summit electric water pump will this stop it from leaking or do i have to buy a new factor water pump to get a new housing. Confused because dont these electric water pumps just bolt up to the stock water pump housing which is where the weap whole is at.
thanks for your help
Old Mar 1, 2005 | 10:21 PM
pHEnomIC's Avatar
Re: water pump weap whole question
I believe the electric pump has a plug that goes into the weep hole in place of the bearing.
Btw, if you end up going oem, autozone has reman pumps for 45 + 15core and got 3$ thermostats. You also get 1 year warranty. I did this and it worked fine.
Old Mar 1, 2005 | 10:30 PM
mmmchickenboy's Avatar
they were $140 2.5 years ago! damn. they only had new ones back then.
EDIT: those $3 thermostats are NOT the correct ones for this engine. you need one that has two valves.
Old Mar 1, 2005 | 10:56 PM
Dave88LX's Avatar
The CSI uses what looks basically like a freeze plug that you pound into the back of the water pump and seals off the hole.
Old Mar 2, 2005 | 09:56 AM
350pride's Avatar
Talking Re: water pump weap whole question
Thank goodness and yall. See I had already order the electric pump when it dawned on me that the pump was leaking from the weap whole, so i was like oh no! but now every thing makes sence.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
