Replacing Steering Rack. How much PS Fluid do I need??
Old Mar 4, 2005 | 09:36 AM
Fast96WS6's Avatar
Exclamation Replacing Steering Rack. How much PS Fluid do I need??
I'm replacing the PS Rack today. How much PS fluid do I need.
Also, do I need a special tool to disconnect the Tie Rods?
Anyone have any experience with this? What should I look out for?
TIA
Old Mar 4, 2005 | 09:43 AM
madwolf's Avatar
Re: Replacing Steering Rack. How much PS Fluid do I need??
I wouldn't imagine it would use more than 2 quarts. After my engine swap, I took off the cradle from the car and it didn't use a full quart bottle afterwards, so I'm sure it won't take more than 2 bottles after a full drain.
Are you reffering to outer tie rods? Disconnect from inner tie rods or from the knuckle?
From inner tie rods, it's a piece of cake. Just hold down the nut and unscrew the tie rod. Real easy.
From the knuckle, it MIGHT be a little more complicated, but not as bad as taking the knuckle off the ball joint. It may be stuck in, so you might want to use a fork to take it out, but I just gave mine a light tap with a rubber mallet.
Old Mar 4, 2005 | 10:43 AM
Fast96WS6's Avatar
I'm looking to remove the Tie Rods and Steering rack together, so I imagine I would have to remove the tie rods from the ball joint?
Old Mar 4, 2005 | 10:50 AM
madwolf's Avatar
No, you disconnect them from the steering knuckle. You'll see it once you take the wheel off.
Old Mar 4, 2005 | 02:53 PM
OBE1 95Z28's Avatar
Harbor Freight sells a tie rod spearator (puller type tool) for around $8 that makes separating the tie rod from the steering knuckle really easy. As far as fluid goes, I think you'd be safe with 2 quarts; you can always buy a 3rd and take it back. Use a flare wrench (18mm) on the steering lines where they mount to the rack.
Victor Lamb
Aug 26, 2017 02:52 PM
mspennyhughes
Mar 1, 2015 03:50 PM
Airplanedoc
Feb 1, 2015 07:14 PM
Hurin
Dec 13, 2014 07:38 PM
ro2207
Dec 4, 2014 06:18 PM
