Doin an oil change
Old Mar 6, 2005 | 06:53 PM
blind527's Avatar
Doin an oil change
So yeah, I'm doing MY first oil change attempt, as I have never had the tools to do one myself. I think I'll be getting M1 Synthetic 0w-30 that seems to be pretty popular for the Summer? Anyways, what do you guys put the oil in? I'm pretty sure an oil pan right, but how much are those? THAT I do not have. After I flush my oil system, how much should I put in, 5 or 6 quarts? I can't seem to find the German Castrol Syntec stuff, so I'm going with M1 cause I hear it's pretty good. I have also considered Royal Purple motor oil or Red Line at 5w-30.
Old Mar 6, 2005 | 07:50 PM
Bawls's Avatar
Re: Doin an oil change
http://www.bfranker.badz28.com/fbody/lubeoil.htm
Old Mar 6, 2005 | 08:13 PM
blind527's Avatar
That isn't what I was asking, but thanks. I know what oil i'm doing and HOW to change it, I just need to know how much is a pan to put oil in.
Old Mar 6, 2005 | 08:25 PM
blitzer454's Avatar
You need at least a 5 quart oil pan to catch the oil. I have a rectangular oil catch container and on the top of the container it has a recessed area with 2 plugs that let the oil drain to the inside of the container. Kind of like a built in funnel. It also has a cap to drain the oil out of the container into another container. Most auto repair places will take the used oil with no charge. At least around here they do.
Old Mar 6, 2005 | 08:34 PM
blind527's Avatar
How much is that oil pan?
Old Mar 6, 2005 | 08:37 PM
Bawls's Avatar
Any oil pan will work. Mine holds 15qts or 20 i believe.
Old Mar 6, 2005 | 09:33 PM
tomcat87's Avatar
Are you asking how much they cost? Should be easily under 10 bucks.
Old Mar 7, 2005 | 12:12 AM
z28forlife's Avatar
This is the first time you have had the tools to do an oil change? All it takes is a 15mm socket or wrench and a jack which should come with the car. I'm not trying to sound like an a$$, i guess its just because I try to do everything on my car myself and I think everyone else does the same
I would run 10w-30 moblil one synthetic in the summer because in the summer the oil will run alot hotter and the thicker you have it the less it wil break down. I run 5w-30 in the winter and 10w-30 in the summer. Just my $0.2
Old Mar 7, 2005 | 02:56 AM
Copernicus325's Avatar
How often does everyone change their tranny fluid and the oil in the rear differential?
Old Mar 7, 2005 | 09:00 AM
blind527's Avatar
Yeah I live with my mom, my parents are divorced and we never had any tools in the past year for me to do my oil change. Sounds kind of corny, but I got used to it
Old Mar 7, 2005 | 08:40 PM
tend2609's Avatar
Drain the oil and put the plug back in the oil pan(the one on the car), remove the old filter and install a new one. Then place the car on a level surface and dump in 5 quarts. Start the car and let it run for about 10 seconds. Then go and check the oil level and add as needed...I think it is 5.5 qts ne way. But that depends on what filter you use.
Old Mar 7, 2005 | 08:44 PM
blind527's Avatar
Why does it matter if I have the car on a flat surface while i'm dumping the oil in, just as long as I check it when it's on a flat surfact, I should be good. I may be needing to add 1 more quart in, but everything seemed fine when I checked it.
Old Mar 7, 2005 | 09:10 PM
MellowZ's Avatar
Because the oil pan (the one bolted to the engine) is designed to let all the oil flow out when it's level. If the car is on an incline some of the old oil won't flow out.
Old Mar 7, 2005 | 09:30 PM
blind527's Avatar
The oil has already been drained. I'm talking about adding the new oil in the crankcase.
Old Mar 7, 2005 | 10:11 PM
MellowZ's Avatar
I suppose to be pedantic the car does not need to be level at the moment when you're pouring the oil in, but it should be when you're measuring the oil.
The problem is that you can't run the car with all the oil out, so you want to move it to a good spot before you start tearing it apart.
