EGR stud, need bolt size.
Old Mar 2, 2005 | 04:05 PM
Silvershark's Avatar
I ruined the old bolts when taking them off and I am in need of new ones for the studs that hold on the EGR stuff. I purchased the EGR block off plates and I am trying to locate the correct bolt size for the studs.
Thanks.
Old Mar 2, 2005 | 05:18 PM
Re: EGR stud, need bolt size.
5/16"-18
Old Mar 2, 2005 | 08:26 PM
Ok thanks, I went down to the local hardware store before I got your post and got some 5/16" nuts but it looks like the wrong thread size because they wont thread on like the old ones did. I guess I will head back.
Thanks for the info.
Old Mar 2, 2005 | 09:02 PM
97pontta's Avatar
They are a metric thread. 4 mm by 1.5 I think, its the standard 4mm thread.
Old Mar 2, 2005 | 09:18 PM
Not on mine.
Old Mar 2, 2005 | 09:25 PM
Doh. Well I was able to get the standard 5/16 x 18 nut over the studs, however the flang style at 5/16 x 18 did not work. So I am not sure. I have 1 flang style that I salvaged from the removal of the EGR and it threads all the way down to the intake. The new 5/16 x 18 flang ones that I purchased from the store do not. They stop right as you get to the end of the nut and will not thread any deeper. I figure since the block off plates are aluminium the stainless steel 5/16 x 18 nuts will match so I will just use non flang style.
If anyone has anymore insite as to what style/size flang nut would work I would appreciate it. I just like to make sure everything is as stock looking as possible.
Old Mar 2, 2005 | 10:08 PM
97pontta's Avatar
Originally Posted by shoebox
Not on mine.
Your right mine won't fit a 4mm either because they are 8 by 1.25mm. I had a brain fart when I typed 4mm
8mm=.3149 inches
5/16=.3125 inches
They are very close in diameter as well as pitch
5/16-18 pitch =.055 inches
8by1.25pitch =.0492 inches
Sorry for the confusion
Old Mar 2, 2005 | 10:24 PM
5/16-18 is spec'd in the parts book, plus the nuts are 1/2 wrench size. That pretty much makes them non-metric the way I see it.
Old Mar 3, 2005 | 01:42 AM
Normally I would agree with ya shoebox, but I tried the 5/16 x 8 size flang size and they defiantly dont fit. I think the parts book is referring to a non flanged style or something. A normal 5/16 x 8 nut does fit however.
Old Mar 3, 2005 | 07:53 AM
I didn't say 5/16 x 8.
All I said was the thread and pitch were 5/16-18. The nuts you choose are up to you.
Old Mar 3, 2005 | 08:05 AM
1-bad-z28's Avatar
it is 5/16" wide with 18 threads per inch thread pattern. Should not matter if it has a flange or not unless it is a locking nut. If it screws down most of the way, sounds like you have the wrong thread pattern
Old Mar 3, 2005 | 09:23 AM
curly's Avatar
As far as the studs are concerned, what is the thread size for the part that is threaded into the intake? When I bought my intake for P/P, the studs had been removed. I have the blockoff plates and now need to know the thread size of the stud in the intake. Is the same size listed above?
97pontta, I really like your intake... bet that would look good with my polished valve covers .
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
