is port matching worth while
Old Mar 7, 2005 | 11:53 AM
todd smith's Avatar
i am thinking of port maching my heads and intake becuase there of please let me know what you guys think plus hp. gains
Old Mar 7, 2005 | 01:49 PM
DarkHorse's Avatar
Re: is port matching worth while
From what i've read around here - no. I've picked up that a good valve job would be better than simply gasket matching the heads. Then again, there are a couple of porters on this site so it may just be a marketing ploy?
I have no dyno numbers to support any of the above so take it lightly.
Old Mar 7, 2005 | 02:03 PM
raroz28's Avatar
It helps flow, for obvious reasons. Opening the ports more gets the air in there, but it's in the head that the real porting is done. You can do the port matching yourself.
Old Mar 7, 2005 | 02:12 PM
1-bad-z28's Avatar
your valves will only allow so much air through
Old Mar 8, 2005 | 07:23 AM
todd smith's Avatar
thanks i have the heads off the car this is why i am asking this i am having a good vaulve job done
Old Mar 8, 2005 | 07:29 AM
LameRandomName's Avatar
They're already off? Heck, do it then. It's not like it's going to hurt you.
Old Mar 8, 2005 | 03:06 PM
todd smith's Avatar
what kind of hp gains is it going to get( plus i have hot cam 1.6 rr 2600 stall lt headers cold air no cat no egr ) will this car hit the 12 with slicks and gears
Old Mar 8, 2005 | 04:56 PM
Z95m6's Avatar
I've read many articles on porting and they all said that gasket matching is pointless. Opening up the bowls is where the real flow gain occurs.
pimpen1024
Aug 19, 2015 08:36 PM
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
Dmonty
Jun 2, 2015 11:19 PM
TitoPR221
May 26, 2015 12:20 AM
