th350 convertion question
Old Mar 7, 2005 | 12:36 PM
meangrn94ta's Avatar
what dipstick will work with the th350 convertion in a 94TA? i was told the the stock 4L60E dipstik will not. what dipstick should i use?
Old Mar 7, 2005 | 12:40 PM
BRENTT94Z's Avatar
Re: th350 convertion question
I went the 350 route once. I used the dipstick that came w/ the Trans.
It took alittle bending to make it fit properly but it worked fine.
You could also go the flexible route from summit.
Old Mar 7, 2005 | 11:15 PM
i also have the deep pan on it i think it take an extra 4 qrts is there a particular length i need to get?
Old Mar 8, 2005 | 07:41 AM
BRENTT94Z's Avatar
Never used a deep pan, but my guess would be, It uses the same dipstick length. The pan wont raise the level of the fluid. Whether you have a deep pan or not the fluid level should stay the same.
Brentt
Old Mar 8, 2005 | 09:58 AM
true that does make sense i supose LMAO never really thought about it. i just asuumed since the pan held more that the dipstick should be longer.
Old Mar 8, 2005 | 10:00 AM
well i got the 4L60E out last night it was a pita with out a lift. but none the less it is out and the th350 should go in tonight if my torque arm mount kit comes in today like it is supose to.
Old Mar 8, 2005 | 10:39 AM
aintno6's Avatar
Hey I'm probably going the TH350 route later on. Do you have any good online information on doing the swap?
Like do you have to get a new drive shaft made?
Thanks,
Mike
Old Mar 8, 2005 | 10:45 AM
BRENTT94Z's Avatar
Thanks,
Mike
You can use the same driveshaft
Old Mar 8, 2005 | 10:57 AM
yea brent is right u can use the stcok driveshaft IF u find a long tailshaft th350. also back in the mid to late 80's they made a few fbody with short tail shaft trannys and there for had to have a longer drive shaft. but good luck finding a stock long drive shaft that long. i think they only made them like 2yrs.
Old Mar 8, 2005 | 11:10 AM
aintno6's Avatar
ty guys.
Old Mar 8, 2005 | 11:20 AM
godd luck
Old Mar 8, 2005 | 11:24 AM
Z06Z28's Avatar
just curious..which th350 did you go with, TCI?
Old Mar 23, 2005 | 06:14 PM
OutsiderIROC-Z's Avatar
What is required as far as wiring goes with this swap? I have a friend who is contemplating this swap as he has a few TH350's laying around.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
ChrisFrez
Feb 15, 2015 07:49 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
86ZZ4
Aug 22, 2002 08:50 AM
