Those with the LE3 kit...
How do you guys like it? Anyone running it on an A4 setup? What gears and stall do you have? Anyone have some dyno sheets or sound clips I can hear?
I plan on running this package along with my fully forged 355 either to be sprayed big time or boosted around 12-16 lbs.
Re: Those with the LE3 kit...
The head/cam package is designed for a 3.73 or higher gear with a 3500 or bigger stall in a A4 setup.
If you want a cam to work for N2O or Boost make sure you tell Lloyd so the proper changes can be made to the camshaft.
Bret
Bret
Hyperspeed97z28
Aug 21, 2003 12:23 PM
