Please Help, Check engine light on and car running rough????
Old Mar 4, 2005 | 11:43 AM
keng's Avatar
Hey guys, I need some help. I have a 97 camaro LT1. I was on my way to work this morning on the freeway i passed a car, then my check engine light came on and started flashing for about a minute. When I got to my off ramp and stopped it was running really rough and engine light stays on. What do I check? How can I pull the codes?
Old Mar 4, 2005 | 12:03 PM
Re: Please Help, Check engine light on and car running rough????
Autozone will pull the codes for free or you can buy a scanner.
Old Mar 4, 2005 | 02:01 PM
transamdude95's Avatar
Have any suggestions on what kind of scanner to buy? I've got a 95, so Autozone can't help me
Old Mar 4, 2005 | 04:33 PM
You might want to try a search... I've posted lists and summaries of capabilities several times. There is a summary of hardware and software in my online writeup, but a lot of the "links" are out of date.
http://members.aol.com/FWForsythePE/HowTo/Scanner.htm
Old Mar 4, 2005 | 04:46 PM
keng's Avatar
Is there a way to pull the codes using the OBD2, meaning with out a scanner, where you count the number of times the check engine light blinks?
I know on my 82 we use a jumper wire or paper clip.
Old Mar 4, 2005 | 05:25 PM
No... you can't "flash" the codes with a paper clip on any LT1 after 1993. Harbor Freight sells a "code only" OBD-II scanner for $40. Brent Franker bought one and it worked fine.
Old Mar 9, 2005 | 12:11 PM
keng's Avatar
What's up guys, I puled the codes, it says I have a rando misfire, what gives??
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
ro2207
Dec 4, 2014 06:18 PM
Scottylt1
Dec 4, 2014 12:31 PM
Jul 4, 2005 05:00 PM
