spark plugs and wires 96z
Old Mar 7, 2005 | 12:53 PM
FAST96Z's Avatar
Angry spark plugs and wires 96z
hay guys neeed a little help im changing my plugs and wires and just wondering if anyone can tell me the easiest way to change the passenger side and to change the last wire on the drivers side if anyone can tell me an easier way at this id appreciate it
Old Mar 7, 2005 | 12:59 PM
FryedClutch's Avatar
Re: spark plugs and wires 96z
passenger side is a biotch and the only way to make it easier is to take out the starter
last wire on D side is in a trough thing on the motor ya gots to get it outta there then its easier
but plugs and wires with stock manifolds on these suck ohhh and im perty sure that this question has been answered before so it could save you time to just use the search feature good stuff
Old Mar 7, 2005 | 01:00 PM
jsetzer's Avatar
With factory manifolds?
I had to get the drivers back one from the bottom. I was able to get all the pass side from the top, but it is much easier to unbolt the starter and get those back 2 from the bottom.
If you still have all of the AIR and factory manifolds you just need a lot of patience.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
