What valve springs should I go with
Old Mar 4, 2005 | 08:59 PM
JS_CZ28's Avatar
Got a LPE camshaft along with 1.7 rrs. I got everything to do the swap. I am just down to the valvespring angle right now. it is the lpe 213/219 cam lift with 1.7rrs is .523/.533 What valve springs should i go with, and can I use the stock seats and stuff, or is there a kit I can get? My cam swap friend refuses to work with shims to anything with shims is out of the question i guess. lol
Old Mar 4, 2005 | 09:36 PM
raroz28's Avatar
Re: What valve springs should I go with
CC 986 would be fine. CC987 has more of a max lift, and is a slightly stronger spring. 986 max lift .560, 987 max lift .600. Both are dual coil.
Old Mar 4, 2005 | 09:41 PM
1racerdude's Avatar
The cam manufacturer are the best people to ask and not a lot of opinions that may or may not work with your set up.
Old Mar 4, 2005 | 10:36 PM
JS_CZ28's Avatar
the springs the recommend are hotcam springs.... i would use them except im using 1.7 rrs. so I gotta use something a bit more stiffer. do the 986s drop right in??? what is needed to use them
Old Mar 4, 2005 | 11:54 PM
FastZ8's Avatar
comp # 987-16. That's what im running
Old Mar 5, 2005 | 12:00 AM
sssalah's Avatar
These 986 will require locators pn 4771 and the specific retainers and locks.
Other options are Comp Behives, Crane 10308.
Whatever spring you choose, you must check installed hight and bring them close together by using shims.
Old Mar 5, 2005 | 08:19 AM
JS_CZ28's Avatar
Im going to go with the kit crane offers, its everything I need to get it done. Thanx guys.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
