easiest way too drain coolant
Old Mar 5, 2005 | 12:04 AM
simple's Avatar
swapping optis in a week or 2 (again lol)
i have an electric water pump, is there a way i can use that too my advantage too drain the coolant?
would i be best off too drain it from the block with the pump running, assuming the thermostat is open?
anyone have any tricks to draining it without a huge mess that i usually end up with?
Old Mar 5, 2005 | 04:15 AM
1racerdude's Avatar
Re: easiest way too drain coolant
There are block drains on both sides of the block.Pass side is the knock sensor the drivers side is in the same place with a pipe plug.
Use a 6 point socket and 1/2" drive ratchet on the drivers side it is tight and a good open end on the knock sender.
The radiator has a valve.
Old Mar 5, 2005 | 04:43 AM
AdioSS's Avatar
West South Central Moderator
you'll be replacing the hoses with new ones anyway while you have the system open, right? Just cut the bottom hose
Old Mar 5, 2005 | 08:42 AM
moparman's Avatar
Pull the bottom hose off, and have a catch pan in position. You'll be surprised how fast it will drain.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
