Throwing code P1860...help plz
Old Mar 7, 2005 | 09:34 AM
acid5868's Avatar
**I tired the Drivetrain section with no luck **
I just completed swapping out the 4l60e with another 4l60e in my 97. The moment I hooked the battery back up it threw a code. Scanned the car and it shows the code as: DTC P1860 TCC PWM Solenoid Circuit Electrical.
I am at a loss as to what exactly that means or how I go about checking to see what is causing it. More than anything I need to figure it out and get it fixed asap.
When I did the swap the only difference in the trannys was the electrical connector on the tail shaft. My old one was on the passenger side with a small plug, the New tranny had it on the drivers side and its a bigger connection. Since I had the other plug and the wires looked identical, I would assume its safe to splice the connector and plug it in. Not too sure what the sensor is.
Anyone have any input or advice. Help is greatl appreciated.
Old Mar 7, 2005 | 06:51 PM
acid5868's Avatar
Re: Throwing code P1860...help plz
TTT.
I am completely lost, praying someone may have some info for me. Everything I find on the net is just the description of the error .
Drtryder
Apr 22, 2015 04:17 PM
Apr 16, 2015 09:57 AM
captcorvette
Mar 7, 2015 12:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
