Removing crankshaft pulley
Old Mar 6, 2005 | 01:28 PM
CheshireCat's Avatar
What is the best way to hold the crankshaft pulley still while trying to remove the three bolts that hold it in place? When I try to loosen those bolts, the pulley turns... I looked at the diagram on Shoebox's site, but it's still not clear...
Time to break out the Helm Manual...
Thanks,
Steve
Old Mar 6, 2005 | 01:37 PM
redzracing's Avatar
Re: Removing crankshaft pulley
just leave the belt on it and try to break them loose, the compression of the engine should hold it from turning over, it works on mine but you really shouldve even need the belt on it
Old Mar 6, 2005 | 01:41 PM
I'll try putting the belt back on and see if that helps... The Helm manual didn't offer any suggestions...
Thanks,
Any other suggestions?
Old Mar 6, 2005 | 01:54 PM
Putting the belt back on worked.
Thanks,
Steve
Old Mar 6, 2005 | 04:55 PM
sbs's Avatar
sbs
Glad that worked.
For the next person that searches - just put a breaker bar on the big bolt in the middle.
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
