To much oil bad??
Old Mar 6, 2005 | 08:12 PM
nonamez28's Avatar
To much oil bad??
well the other night i slapped some oil in and overflowed it, and just wondering if it will hurt it..
but i will be changing oil this week tho
Old Mar 6, 2005 | 09:32 PM
Re: To much oil bad??
Overflowed, where? What does the dipstick say? Drain it until the level is correct.
Old Mar 6, 2005 | 09:34 PM
raroz28's Avatar
This question came up in an engine class once... I guessed it would cause an increase in crankcase pressure, maybe cause blowby, etc... Dont know how much truth is behind it, but the way the instructor put it was, too much oil can snap an iron crank. He said the iron is very brittle, and filling it up too much and having the crank smack it at high speeds can damage it. I didn't buy into it too much, and I wouldnt worry about it. I would probably just check the dipstick, and drain a little at a time until it's in operating range.
Old Mar 6, 2005 | 09:53 PM
All4Chevy's Avatar
If you filled it too much, don't drive it at all. Don't even start the engine unless you got the right amount in there, will definetly cause some problems if its really over full.
Bill
Old Mar 6, 2005 | 09:59 PM
Jameslt1TA's Avatar
overfilled or overflowed...if you overflowed it, that is alot of oil.
Old Mar 6, 2005 | 10:14 PM
nonamez28's Avatar
i was looking at the stick wrong, it is in the operating range........ sorryguys
Old Mar 6, 2005 | 10:53 PM
Doh!
Old Mar 6, 2005 | 11:03 PM
nonamez28's Avatar
no kidding, im a dumbass
Old Mar 7, 2005 | 09:15 AM
1stz28's Avatar
If it is overfilled too much it can cause the crank throws to agitate the oil enough to make it foam up and then you can actually lose oil pressure. Seems wierd but you can lose pressure from too much oil. That was a question on the ASE engine repair test.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ad356
Apr 11, 2015 08:49 AM
captcorvette
Mar 7, 2015 12:37 PM
