coolant flush help
Old Mar 4, 2005 | 07:45 PM
Killaz's Avatar
coolant flush help
So me and a buddy are changing the coolant in his 96 ss. We flush the coolant and refill with the fluids. Now the car just over heats. Looks like the t stat does not open. Whats up?
Old Mar 4, 2005 | 09:51 PM
OBE1 95Z28's Avatar
Re: coolant flush help
Did you burp the system to get all the air out? There are 2 bleed screws on the top most coolant hoses that need to be bled to get all the air out. Also check the coolant level in the over flow tank to make sure there some there.
Old Mar 4, 2005 | 09:53 PM
OBE1 95Z28's Avatar
Here's a link to a detailed procedure from Shoebox's site:
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Mar 4, 2005 | 11:35 PM
phinger23's Avatar
change the tstat and change the radiator cap. bleed the system as well, but regardless if your tstat is not opening...then thats the reason why your car is overheating
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
