How Much Should the RPM's Bounce?
Old 03-04-2005, 04:09 PM
V-EIGHT's Avatar
I just bought a 93Z with a Comp cam 227/233 .560/.569 and Pro-Magnum 1.6 Roller Rockers. The computer has been done by PCMforless. After it comes to operating temp, and it sits at idle for a minute or two, the RPM's start surging from 600-900, not real fast like Ive seen high performance carb'd engines do, but not extremely slow. This is normal for that size cam?
Im just getting use to the car and the things it dose and the sounds it makes, so I'll prolly have more questions in the next few weeks
V-EIGHT is offline
Old 03-04-2005, 04:49 PM
Re: How Much Should the RPM's Bounce?
Questions like this should be posted in "LT1 Engine Tech" for the best responses, not in "Advanced Tech". I'll move it for you.....
Injuneer is online now
Old 03-04-2005, 05:26 PM
ChrisUlrich's Avatar
My car doesn't do that
ChrisUlrich is offline
Old 03-04-2005, 05:43 PM
V-EIGHT's Avatar
Is your engine stock?
V-EIGHT is offline
Old 03-04-2005, 08:35 PM
V-EIGHT's Avatar
Mabey its just searching for an idle?? No SES light or stalling. If thats all it is, what can fix it?
V-EIGHT is offline
Old 03-04-2005, 08:50 PM
same cam
Old 03-04-2005, 08:52 PM
V-EIGHT's Avatar
Who did your computer?
V-EIGHT is offline
Old 03-04-2005, 09:14 PM
V-EIGHT's Avatar
Now Im pretty sure its just searching for an idle. Shouldnt the computer reprograming taken care of that?
V-EIGHT is offline
Old 03-04-2005, 09:31 PM
1racerdude's Avatar
Throttle blades been opened?
Sounds like your IAS motor needs cleaning because it can't adjust quick enough.
1racerdude is offline
Old 03-05-2005, 06:45 AM
V-EIGHT's Avatar
How do I clean that?
V-EIGHT is offline
Old 03-05-2005, 09:31 AM
1racerdude's Avatar
Get some carb and choke cleaner,take it off and clean the catbon and sludge.
Old 03-05-2005, 11:31 AM
TransAmGT's Avatar
I have a cc306 and my idle sits rit on 925rpm just like i set it...does move at all!
TransAmGT is offline
Old 03-05-2005, 01:27 PM
V-EIGHT's Avatar
At least mine dosent bounce all over the place. just 200-400 rpm's. Im gonna be taking to get a dyno tune, so they will taking care of everything.
V-EIGHT is offline
93 RedBird
11-15-2015 08:24 AM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
drt
09-27-2015 04:39 PM
KYWes
09-26-2015 08:49 AM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: How Much Should the RPM's Bounce?
