Oil Leak At Back Of Engine
Old Mar 5, 2005 | 05:13 PM
dgiven's Avatar
I have a 93 firebird with a 5.7 litre. I had an oil leak at the backof the engine in the fall and thought that it was the rear main seal, I have changed it and the leak is stil there. I cant see exactly where the oil is coming from but it is from somewhere at the back of the engine possibly the intake manifold. I was just woundering if there could possibly be anywhere else that the oil could be coming from. The oil is running down the right side of the bell housing.
Thanks for any help
Old Mar 5, 2005 | 05:32 PM
Kataklysm's Avatar
Re: Oil Leak At Back Of Engine
Its most likely the intake manifold leak. It's very common on these cars. I just did mine.
Old Mar 5, 2005 | 05:37 PM
dirtybird96's Avatar
My vote is for intake.
Old Mar 5, 2005 | 05:56 PM
black95z0122's Avatar
sounds like notorious lt1 intake leak. I did mine. It took me a while to figure out where it was comming from. I guess what happens is that the egr pipe at the back of the intake manifold gets really hot and the factory sealant at the back of the manifold gives way. Once u get in there u can confirm that that was the problem if u see disscoloration on the old sealant. Just take off the manifold and replace the sealant and gaskets. i used purmatex ultra copper and had no problems just remember to torque the bolts in the right order and the right amount. Shoebox's site should have the torque specs.
Old Mar 5, 2005 | 07:13 PM
dgiven's Avatar
Thanks guys for all of the replies and help. I was just woundering if there is a site that gives you the steps in doing the repair and was also woundering what this shoebox site is I have never heard of it before.
Thanks again
Old Mar 5, 2005 | 09:32 PM
ChevyTuffD.A.'s Avatar
Just do a search for Shoebox's name and then find the links in the bottom of his signature. He does have a section for replacing the intake manifold and it is very helpful. Good luck with the repair.
PCLZ28
Dec 24, 2015 05:19 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
