NEED TO HIT 12s
Old Mar 6, 2005 | 10:34 PM
badasschevy625's Avatar
NEED TO HIT 12s
alright im getting 4.10s soon i would like a formula for me to defintly break into the 12s perfebly na with just bolt ons and i really dont want to use a stall thanks
Old Mar 6, 2005 | 10:42 PM
ChevyTuffD.A.'s Avatar
Re: NEED TO HIT 12s
I am going to say your probably going to need the stall to push u into the 12's.
z28marine's Avatar
Re: NEED TO HIT 12s
LT headers, gears, cutout, slicks
Re: NEED TO HIT 12s
you really think that will hit 12s?
Old Mar 7, 2005 | 12:13 AM
JBird33's Avatar
Re: NEED TO HIT 12s
Maybe MAYBE once before you grenade the rear end. A stall or cam would really help alot....
Old Mar 7, 2005 | 12:15 AM
madwolf's Avatar
Re: NEED TO HIT 12s
A4 cars are not as abusive as M6 on the rears. You should be fine unless you have a truckload of miles on it.
Old Mar 7, 2005 | 12:42 AM
96ta(nick)'s Avatar
Re: NEED TO HIT 12s
4.10s + stock rear = BOOM! Good luck.
Old Mar 7, 2005 | 12:45 AM
madwolf's Avatar
Re: NEED TO HIT 12s
I run a 4.10 on slicks in an A4. No boom.
Old Mar 7, 2005 | 12:57 AM
JBird33's Avatar
Re: NEED TO HIT 12s
Madwolf,
Do you use the stock rear-end, or are you using something built, like a zexel-torsen carrier and all that jazz? If it is stock, that'd be good news for me to hear, just because I want to build my car but want to hold off on the rear-end for as long as possible. I'm gonna throw some gears in there but I really don't want to have to use an aftermarket carrier or a 12-bolt.
Old Mar 7, 2005 | 01:04 AM
White_96_SS's Avatar
Re: NEED TO HIT 12s
yea is it stock or what??
Old Mar 7, 2005 | 01:06 AM
madwolf's Avatar
Re: NEED TO HIT 12s
I bought the rear-end used and it was out of an M6. It has whiney 4.10 Richmond gears in it and new axles/seals/fluids. I don't think it has a different posi in it.
I didn't run very fast on it, but it still held up to the track abuse and the occasional flooring on the streets.
Here's my 12.68 run.
I'm switching to a 6 speed very soon, then heads later on, so it will be coming out because I'm pretty sure it won't last long with my granny shifting.
Old Mar 7, 2005 | 01:08 AM
Re: NEED TO HIT 12s
So most likely its not factory stock..
So ur in DeKalb huh..interested in any illeagal street racing this summer??
Old Mar 7, 2005 | 01:11 AM
madwolf's Avatar
Re: NEED TO HIT 12s
Yea, it has a couple of things.
I don't race on the streets anymore. If you want to take it to the track naturally aspirated versus naturally aspirated, then sure!
Old Mar 7, 2005 | 01:19 AM
Sweetred95ta's Avatar
Re: NEED TO HIT 12s
All I can say is bolt ons and a diet. I got my car to 13.3's with bolt ons and through full exhaust and full weight. 2.0 60 ft. But I haven't heard of a whole lot of them going much faster than that w/out a stall or the obvious heads/cam or n02. I had a custom tune also. And 3.73's. And a Shift kit. Good luck though.
Benji
Old Mar 7, 2005 | 07:35 AM
"White Knight"'s Avatar
Re: NEED TO HIT 12s
I wonder what will break on mine first when i run the E.T.'s this summer
I sure hope the zexel-torsen is worth the money
