Fronnt crank seal replacement
I'm going to replace the front crank seal this weekend. Is there anything else, like other gaskets etc., that I will need when I replace this. I dont know what all needs to come off before this, like maybe something else with a gasket that should be replaced at the same time.
Thanks alot
Thanks alot
Re: Fronnt crank seal replacement
Most of the time it is oil coming from water pump or opti seal, and going down to look lik it is front crank seal. Get the same diameter as crank seal exhaust pipe from any parts store ($3), it will save you lots of time tapping the seal in. Also you will need a gasket puller, the old gasket is kind of impossible to remove without one. Hope this helps
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
