bigger crank, will i need a diff timing set?
Old Mar 6, 2005 | 05:36 PM
Mystic97Z's Avatar
i currently have a stock crank and an lt4 extreme duty timing set. i''m getting a 396 stroker crankshaft, will i need to get a different timing set? thanks
-Jason
Old Mar 6, 2005 | 05:40 PM
rskrause's Avatar
Moderator
Re: bigger crank, will i need a diff timing set?
No, stroke has nothing to do with the distance between the crank and cam centerline.
Rich
Old Mar 7, 2005 | 09:56 AM
Mystic97Z's Avatar
i meant about the gear physically fitting around the crank
Old Mar 7, 2005 | 10:00 AM
1-bad-z28's Avatar
The crank is the same size....the only difference is the stroke. This has nothing to do with the size of journals (main or rod) or the size of the end of it. The only thing that changes on a stroker crank is the distance from the main journal to the rod journal increases giving you a longer stroke.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
1LEThumper
Jul 14, 2003 12:45 PM
MissedShift
Jul 24, 2002 01:37 PM
