overheating problem
Old Mar 4, 2005 | 04:02 PM
chamealeondroptopZ's Avatar
Question overheating problem
ok,Ive been having an overheating problem which I traced to a bad heater core.Coolant was coming out on the floorboard so I decied to bypass it instead of replacing.It solved the water leak but thats it.I also just put a new 180 thermostat in,and fresh coolant.It gets up in the 260 geg area pretty fast.Also,both fans are turning on.What else could it be?Do u think waterpump?I dont see any water coming out of it though.or could it have something to do with bypassing the heater core?what do u guys think?Thanx
Old Mar 4, 2005 | 04:24 PM
joeSS97's Avatar
Re: overheating problem
If you didnt bleed the system,you need to.Look on Shoebox's site.It should be covered there.
Old Mar 4, 2005 | 04:45 PM
americanmusscle's Avatar
I agree, bleed the system and go from there.
Old Mar 6, 2005 | 06:07 PM
just thought I'd update for anyone that might run into a similar problem.I went and got a new radiator cap($4)at the auto parts store,I didnt like the way my old one fit.So far so good no overheating.beats changing a waterpump
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
