stock hardened pushrods
Old Mar 1, 2005 | 10:58 PM
bowtieman_racin's Avatar
Question stock hardened pushrods
Hey guys, I'm almost threw with my heads and cam project. I have factory hardened pushrods with the demple in them. I inspected them all very closely and found one that had a nick in it from where I had a roller rocker come loose a while back. Well I ordered one from gmpartsdirect.com and ordered it for my car it came out to be also a gm high performance part #. But when I got it it has a pink stripe on it but no demple??? Does anyone know if it is the same or the same quality as my stock pushrods? I emailed the gm website and they didn't email me back ( they probably dont want to bother with worrying about a $7 part even though I spent hundreds on my 847cam, rocker studs, guideplates, and other stuff if anyone has any knowledge on this please let me know thanks,
Old Mar 1, 2005 | 11:07 PM
SStrokerAce's Avatar
Re: stock hardened pushrods
I'm guessing this is a 10241740 PR? It's a PR only for SA rockers.
BTW anyone if you go to a setup that uses guide plates make sure you get pushrods that will work with them!!!!!
Bret
Old Mar 1, 2005 | 11:15 PM
actually this is part # 10046173 for 94 z28 camaros its listed as old style for use with guideplates. I think they only put them in 94-95 cars?
Old Mar 2, 2005 | 05:57 AM
any one else know about this? Does the pink stripe stand for hardened? thanks,
Old Mar 2, 2005 | 10:21 AM
91RSLT1's Avatar
Take a file to it and littly scrape it. If it is harderned you won't removed any metal. On a non harderned push rod you would put a little nick or groove where you sracthed it with the file.
Old Mar 2, 2005 | 10:56 PM
I'll have to try that. Gm emailed me back and asked for the vin # for my car and they are supposed to get back with me with an answer. thanks,
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Jul 4, 2005 05:00 PM
