Intake torque question
Old Mar 5, 2005 | 10:58 PM
midwestcamaro94's Avatar
I tried to search for the answer to my question but did not really find anthing like this. I am putting my LT-1 intake back on and need to know if anyone has ever had to use a ft lbs torque wrench and applied inch lb force. My torque wrench only goes as low as 10 ft lbs and I am afraid that if I redneck it with a straight wrench and "feel" how tight it is, that will most likely cause problems down the road. Any ideas. and I already know the obvious to buy a torque wrench that does inch pounds but it is 11 pm and this car needs to be done by tomorrow. thanks for your help
Old Mar 5, 2005 | 11:01 PM
Spinner's Avatar
Re: Intake torque question
I generally snug mine up lightly, then torque.
Old Mar 5, 2005 | 11:11 PM
Adam E's Avatar
well im not sure what it is on an lt1 because i havent done it yet. i was working with my friend and his dad on their 454...we finished putting new pushrods, rockers, etc. anyway long story short we finished up the valvetrain and then put on a new intake manifold...the torque rating was 30 ft. lbs., im not sure what it is on the lt1 but im sure you could find it in a manual...and now that i finished typing all of that and wasting your time i forgot my shop manual just got here so im going to go check what it is...
alright sorry about leaving all that other crap in there. the manual says make a first pass through the bolts/screws/studs and tighten them to 71 lb. in. yes in. then make a second pass and the final torque rating is 35 lb. ft.
hope that helps.
adam
Old Mar 6, 2005 | 01:16 PM
MentalCaseOne's Avatar
I "remember" my book say 35 foot lbs and to go on two steps..
What I did.... on the first try... I went snug by hand only... on the second round went up to 15lbs on the 3rd round I went up to 25lbs and then to either 30lbs or 35lbs..
the chiltons book has the amount of torque required... I didnt need to go so many steps... but it was my first time and I didnt want to bend anything.
Marvin
LT14LIFE
Feb 9, 2015 09:35 PM
CARiD
Jan 27, 2015 06:27 AM
Noenav
Dec 6, 2014 07:35 PM
RedLineRev
Jan 23, 2003 03:51 PM
