Parts needed for cam swap
Old Mar 6, 2005 | 09:50 PM
1QuikTransAm's Avatar
Well i'm gonna be doing a cam swap in the ta in a month or so and i need to make a list of all the stuff i'm gonna need. So far I have:
-Cam
-Springs, retainers, and locks
-1.6 rr's
-Pushrods
-Gaskets
-Timing Chain set
I've got most of the specific parts picked out except for the timing chain. Not sure whether to go with a LT4 HD or a double roller w/ electric waterpump. Which one would be better to go with?
So is there anything else i'm gonna need for the cam swap?
Thanks alot in advance guys!
Old Mar 6, 2005 | 10:03 PM
Jameslt1TA's Avatar
Re: Parts needed for cam swap
I just went with a stock replacment timming chain. Beware of broken parts and other things and budget for them because they can add up quick. I was gona do a cam swap and got it out of there and saw that the front cam bearing was terrible, so i took out the engine to have new bearings put in, then i said hey why not port the heads, why not re ring and bearing it...anyways a $800 project turned into 2k plus.
Old Mar 6, 2005 | 10:04 PM
Jameslt1TA's Avatar
Also you may want a tune for it...mine runs like total crap on the stock tune.
Old Mar 7, 2005 | 01:20 AM
Well i was definitely plannin on gettin a dyno tune after all the work was done. I know there's a possibility that I could run into some problems like you said about the cam bearing; that's why i'm trying to figure up what all i'm gonna need so I can save up for the parts and some extra in case extra work needs to be done. Thanks for the reply.
Anyone else have any inuput?
Old Mar 7, 2005 | 01:50 PM
crAzy95z28's Avatar
well while ur at it..i would replace the spark plugs and wires along with a tune, and a new coil or even get a msd ignition box, possibly new opti or DYNASPARK or go with a delteq~
Old Mar 7, 2005 | 03:53 PM
Zachz28's Avatar
How many miles did you have on your T/A?
Old Mar 7, 2005 | 10:42 PM
Oh yeah, I forgot to mention i've already got the new plugs and wires...lol. The coil is fairly new with only about a thousand miles on it. I dont know about the new opti tho...might just wait until this one dies.
Thanks for the input.
Anything else guys?
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
chuyz28
Nov 25, 2014 11:14 PM
Elcojoe
Nov 17, 2014 10:27 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
