Oil Change Help!!!
Old Mar 3, 2005 | 08:38 PM
LUDA0840's Avatar
Question Oil Change Help!!!
How many oil containers do I need to pour onto my 96 z28? For the oil change?
Old Mar 3, 2005 | 08:40 PM
LT1 Bunny's Avatar
Re: Oil Change Help!!!
5 quarts
Old Mar 3, 2005 | 08:43 PM
turbo_Z's Avatar
Make sure you fill the new filter up with oil before you put it on.
Old Mar 3, 2005 | 08:49 PM
LUDA0840's Avatar
thanks
Old Mar 4, 2005 | 05:03 AM
Brent94Z's Avatar
Super Moderator
http://www.bfranker.badz28.com/fbody/lubeoil.htm
Old Mar 4, 2005 | 10:19 AM
wayfastwhitey's Avatar
I dont mean to highjack this thread, but does it take 5 quarts of transmission fluid to fill an a4?
Old Mar 4, 2005 | 10:31 AM
From the 1994 owner's manual:
Automatic Transmission
Drain and Refill . . . . . . . . .. . . . . . . . . . . . . . . 10 pt. (4.7 L)*
Overhaul
VIN Engine Code S . . . . . . . . . . . . . . . . . . . . . 17.6 pt. (8.3 L)*
VIN Engine Code P . . . . . . . . . . . . . . . . . . . . . . 21.6 pt. (10.2 L)*
10 pints is 5 quarts.
Automatics can be a little tricky. I ususally fill and check the dipstick often (and move the selector through the gears). You don't want to over-fill an auto.
Old Mar 4, 2005 | 10:33 AM
BoobSter-lt1-z's Avatar
Hey Shoebox,
Do you believe it is very possible for your tranny to shift weird if you overfill it a bit?
Old Mar 4, 2005 | 10:39 AM
Over-filling can cause foaming and lack of lubrication. I would imagine it could affect shifting if the fluid supply was aerated.
Old Mar 4, 2005 | 10:47 AM
Thanks, I dont have an owners manual.
Old Mar 4, 2005 | 10:48 AM
Now you do.
Old Mar 4, 2005 | 10:51 AM
Thanks again.
Old Mar 4, 2005 | 11:20 AM
93turbo5oh's Avatar
it could be 4.5 quarts on the oil. every time i go to the autoparts store they try to sell me a 1/2 quart filter for my car which is the replacement now. i always have to specify AC pf1218 which is a 1 quart. im not a big fan of overfilling engines, so it just depends on how big your filter is. obviously get the longer one if you can.
Old Mar 4, 2005 | 02:47 PM
AHAA!
THANKS A LOT SHOEBOX!!!
SpeedJunkee
Apr 23, 2015 09:51 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
