Brake light.........
Old Sep 25, 2003 | 06:24 PM
CHEVYLIFE's Avatar
Angry Brake light.........
When I put down my parking brake the brake light still stays on. Can this mean its just my sensor or can it be something else more serious??? thanks for the info.
Old Sep 25, 2003 | 06:29 PM
Dave89IROC's Avatar
make sure your brake fluid reservoir(under the hood, on master cylinder) is full, some cars will turn the light on if the fluid is low
Old Sep 25, 2003 | 06:36 PM
CHEVYLIFE's Avatar
THANKS
I thought about that and am going to check it when I get out of work.
Also can anyone tell me why I have to push down farther on the brakes to stop Im pretty sure its because i need some new pads.
What are some good kind of brake pads.
Thanks again.
Old Sep 25, 2003 | 06:43 PM
Dave89IROC's Avatar
Originally posted by CHEVYLIFE
THANKS
Thanks again.
how does the car stop?
does it seem to drop the nose alot when you hit the brakes?
if your master is very low, you may have a leak, which will also turn the light on(when the fluid pressure varies from the front to the rear)
Old Sep 25, 2003 | 07:44 PM
CHEVYLIFE's Avatar
Well I wouldn't say the nose drops alot but it does sometimes.
Is there any test to see if there is a leak???
TIA
Old Sep 25, 2003 | 08:17 PM
Dave89IROC's Avatar
TIA
well, if there is a leak, just fill the master cylinder and have someone pump (press, let up, press again, repeat) the brake pedal and you should see fluid leaking onto the ground
also, if the paint on the brake booster under the master cylinder is striped off, you probably have a leaking master(i say probably, because it may also be from spilled fluid)
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
