Next problem w/ mods...
Old Sep 28, 2003 | 12:14 PM
Mr.Whitey's Avatar
I just changed the oil after the cam install and it's filled w/ metal shavings. Should I expect any shavings at all? The bottom of the drain pan w/ covered w/ tiny pieces of different sizes. Can I now expect that something is now FUBAR'ed inside?
Old Sep 28, 2003 | 02:14 PM
TMDZ28's Avatar
Re: Next problem w/ mods...
IMO, your engine is toast
Old Sep 28, 2003 | 02:21 PM
Hyperspeed97z28's Avatar
how many miles did you mod at? metal shaving isnt a good sign, that is for sure..
Old Sep 28, 2003 | 02:22 PM
Zack's Avatar
if im not mistaken, the reason to change the oil right after a cam install is to get the shavings that will be created out.
Old Sep 28, 2003 | 04:39 PM
Mr.Whitey's Avatar
The odometer reads 47K. The only thing that I can see it being that is "ok" is the double roller chain & gears rubbing on the new 95 cover. I don't hear anything like that but then again it does have open headers so I don't know that I would hear it. I would think that anything else kicking out this much metal would be toast. I changed it again after a few minutes of running and still the shavings appeared. About half as many as the first time but still enough to have me VERY concerned. Should I rip it all apart again?
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Teal94V-6
Aug 31, 2002 09:21 PM
