Front End Squels
Old Sep 27, 2003 | 08:31 PM
MuffZ28's Avatar
Front End Squels
On my '96Z, after it warms up, it seems to me as if the front end squeals when I go around corners. At slow or high sppeds. I'vs seen in the repair manual that it doesn't have grease fittings. It says it has plugs, and if you want to be able to grease it, you must install some zerk fittings. Whats wrong w/ my car and is there a cheap/easy way to lube the front end?
Old Sep 27, 2003 | 09:06 PM
pennys58's Avatar
mine does the same thing...does it seem to not be as bad if you are applying the brake? My squeals when I am turning but when I turn with the brake on it doesn't.... I would love to get it taken care of too!!
Old Oct 9, 2003 | 05:07 PM
MRBoss429x's Avatar
I am having the same problem. Its really noticeable and annoying while turning at slow speeds (usually parking). Can anyone shed some light upon this?
Old Oct 9, 2003 | 06:37 PM
Greenlt1monster's Avatar
Check up on your brake pads and see if they're worn/dirty. And make sure it's from the front too. All of the Camaro's that my friend's and I drive have the same problem. All spawning from A sticking brake caliper.. I took all mine apart and re-greased them and I havn't had any problems. Hope it helps.. Maybe it's what your problem is...
Old Oct 9, 2003 | 06:44 PM
96M6's Avatar
had same problem.
Change rotors pads, clean calipers etc.. etc... no more squeek,
Old Oct 9, 2003 | 06:52 PM
1darkz's Avatar
i noticed this problem with aftermarket brake pads on the rear so i changed them and the squeak went away
Old Oct 9, 2003 | 07:54 PM
93Z286Speed's Avatar
i have the same problem.. not a big fan of the squeeking! makes my car seem kinda ghetto
PublicEnemy1
Apr 7, 2015 12:21 PM
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
siguy
Nov 27, 2014 10:07 AM
