anyone know what different wheels weigh ?
Old Sep 26, 2003 | 01:54 PM
Seanndogg's Avatar
The stock 16/8 five stars weigh 26lbs or something ...?
How about Zr1's (SS).......................................?
corvette 5 spoke, Zo6, wagon wheels ?
Old Sep 26, 2003 | 01:56 PM
FyreLance's Avatar
I know the salad shooters are pretty light... they weigh like 1/2 as much as my Formula's aluminum 5-spokes
Old Sep 26, 2003 | 01:57 PM
anaik's Avatar
Scroll down for wheel weights.
http://www.bfranker.badz28.com/fbody/weights.htm
Old Sep 26, 2003 | 02:13 PM
Seanndogg's Avatar
I should have checked there first ...
thanks
All of the stock wheels seem pretty close in weight. I thought the Zr1's would be a lot heavier.
Old Sep 26, 2003 | 02:21 PM
anaik's Avatar
thanks
They are when you put the tires on. My salad shooters with 245's weigh 45 lbs. My ZR1's with 315's weigh 58 lbs. That's on a bathroom scale, so maybe not that accurate.
Old Sep 26, 2003 | 02:24 PM
94formulabz's Avatar
It's not just the weight, but where the wieght is distributed. Even if a larger diameter wheel weighs the same on the scale as a smaller diameter wheel, it can have a larger moment of inertia due to the mass being located further out on the radius. Also, a wider wheel of the same diameter and weight relative to a narrower wheel is more likely to have a larger portion of it's mass outward on the rim of the wheel and will eat up more hp. Not exactly the answer to the question at hand, just something to keep in mind while looking at this stuff
-Brent
Old Sep 26, 2003 | 03:40 PM
TreySpeed's Avatar
On permanent vacation
are you on crack? salad shooters - 22lbs. 98TA 5stars - 16.5 lbs. same scale
Old Sep 26, 2003 | 04:52 PM
blitzer454's Avatar
Boyd Coddington Smoothies 17x10 weighs 26 lbs on the bathroom scale
force10
Aug 10, 2015 08:30 AM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
*Emilia*
May 13, 2015 09:05 AM
