323 to 373 gear change
Old Sep 27, 2003 | 12:05 AM
Fred Jeter's Avatar
Lightbulb 323 to 373 gear change
No improved MPH or ET after the gear change from 323 to 373. 60ft time did not improve, it was unchanged. I thought that I would pickup 2 to 3 tenths, but i didn't.
Old Sep 27, 2003 | 03:07 AM
revtime's Avatar
What exactly are your 60 foot times?
Do you have a stall?
I also changed to 3.73s from 3.23s and did not see a gain but it did spin more off the line.
Since I put in the stall and suspension stuff I can see the gears working better.
Old Sep 27, 2003 | 10:28 PM
Josh-'04 GTO's Avatar
Re: 323 to 373 gear change
What were the times? Were the track conditions IDENTICAL? If not, it's tough to accept your data as proof.
Revtime brings up a good point about the stall speed. Matching that to the powerband of your cam will help out quite a bit.
Old Sep 27, 2003 | 10:46 PM
Gears don't guarantee a drop in E. T. Your setup has to be able to make use of the extra revs you can get from them. Then, there is always the traction issue.
PCLZ28
Dec 24, 2015 05:19 PM
Jul 4, 2005 05:00 PM
naaz90
Jul 27, 2002 08:22 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
