Question about crank's rod journal size.
Old Sep 25, 2003 | 10:30 PM
LT1 S-10's Avatar
Is a 400 crank a wide or narrow rod journal (2.0 or 2.1")? I was told that all 400 cranks are a wide journal. Can anyone confirm this? Thanks guys.
Old Sep 26, 2003 | 10:03 AM
SStrokerAce's Avatar
It's not wide but small journal.
A 400 crank has the larger 2.100" rod journal and a 2.65" main journal. That means you can't drop it into a 350 or LT1 block unless you grind it down. At that point you might as well just buy a Scat stroker crank.
Bret
Old Sep 26, 2003 | 12:28 PM
LT1 S-10's Avatar
I dont understand. Did I get [wide and narrow] mixed up with [large and small]?
Bret
You are talking about grinding the main journals down right? Not the rod journals.
Old Sep 26, 2003 | 01:15 PM
Yeah it's small (2.0") and larger (2.10") journal. You can even go down to 1.88" Honda or Quad 4 Journals.
Yeah you will be grinding down the main journals to have the crank fit in the 2.45" man journals of a Lt1/350 block.
That clear it up?
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
