APHR help!!
Old Sep 27, 2003 | 12:36 AM
ZyberMunster's Avatar
APHR help!!
How exactly does the APHR work?? What's the procedure to center the rear axle?? Any help sites on this??
Laterzzz...
Old Sep 27, 2003 | 12:44 AM
SS Mark's Avatar
take 2 washers tied to a piece of string, tape the string to identical parts of the hatch window so the washer is in hovering in front of the wheel, measure the distance from the wheel(same spot on both wheels) and figure out which way the rearend needs to go from there.
-Mark
Old Sep 27, 2003 | 12:52 AM
That's cool, but do I have to loosen anything on the rear axle?? shocks? LCA's?
**** I'm totally lost on this one!!
Old Sep 27, 2003 | 10:45 AM
Nothing to do but rotate the panhard rod to change its length. Making it longer pushes the body to the passenger side relative to the wheels, making it shorter moves the body toward the drivers side relative to the wheels. Just make sure you have the space equal on both sides when you are done.
Old Sep 27, 2003 | 10:47 AM
Thumbs up
Thanks guys!!!
SS MPSTR
Aug 8, 2008 01:47 PM
Sam Strano
17
Nov 22, 2006 10:02 AM
SOMSS
Nov 12, 2006 06:59 PM
Sam Strano
Oct 6, 2006 12:36 PM
unvc92camarors
Jan 20, 2005 04:46 PM
