oil pressure drops to zero when i hit the brakes
Old Sep 26, 2003 | 02:31 AM
marshall93z's Avatar
does anyone know why this happens?
when i boought then car it had extra oil in it, now i know why!
Old Sep 26, 2003 | 02:57 AM
AndyB's Avatar
Oil pump pickup probably fell off I woudl stop driving the car until its fixed.
Old Sep 26, 2003 | 09:04 AM
apick42's Avatar
I am seeing more and more problems with the oil pressure droping under hard braking is it possible for so many engines to
have the pick up to fall off? This seems to be a common problem.
Old Sep 26, 2003 | 09:09 AM
WayneE's Avatar
I had the same problem... oil pressure dropped to 0 under braking. My pump pickup fell off after an engine rebuild. Had to drop the pan and have it welded together (like I should have done in the first place).
Old Sep 26, 2003 | 11:24 AM
Blown 96 WS-6's Avatar
Ditto here guys. Mine did this as well. It would always come right back up to pressure within seconds. I challenged fate though and drove my car like that for over a year without adverse afffect. Sure enough, when I pulled the motor for a rebuild due to broken ring-lands, the pick-up was loose in the pan. YMMV ;-)
Old Sep 26, 2003 | 11:31 AM
Max 93's Avatar
mine had fallen off too. I had the dealer fix it and it fell off again two months later, they fixed it for free that time.
Old Sep 26, 2003 | 01:03 PM
thanks for the help...
Old Sep 27, 2003 | 06:14 AM
neat's Avatar
LT1's are kinda notorious for pumping the heads full of oil too. It might be that. The drainback characteristics of LT1 heads suck. Under hard braking, most of the oil in the heads goes to the front, where it has roughly half the drain holes to return to the pan through. Coupled with the poor drain characteristics, that can cause what you guys are talking about. Run it 1/2 quart over or port the oil returns in the heads.
Old Sep 27, 2003 | 08:25 AM
scoobysnax83's Avatar
Here's a disclaimer:
Don't weld with oil residue anywhere on your engine. Seems like common sense, but I know of people taking the chance and woosh.... Be careful!
Old Sep 27, 2003 | 10:24 AM
will it hurt to run it 1/2 quart over or maybe even a whole quart?
Old Sep 27, 2003 | 11:06 AM
half quart won't hurt, but I wouldn't go full. You're liable to spring some leaks.
Old Sep 28, 2003 | 12:45 AM
why would that cause it to spring a leak?
Old Sep 28, 2003 | 02:36 AM
neat's Avatar
Runnig it a quart over full will NOT make it leak. How does more oil in the pan equate to more oil pressure? It doesn't.
As long as there aren't air bubbles in the oil when you check it you're fine.
Old Sep 28, 2003 | 11:54 AM
so, it will NOT hurt anything to run an extra quart in it?
Old Sep 28, 2003 | 12:26 PM
ledfootz28's Avatar
how much would a shop charge to change the oil pump??and what kinda pump should we get?i have a new pump laying around witht a new pick up and all i got from pep boys a while ago,its a dynagear high press high volume oil pump is this any good??also what else should i tell a mechanic to change while hes doing the pump,i know to change the oil pan seal and new bolts.
