max compression for pump gas?
Old Sep 28, 2003 | 12:47 AM
marshall93z's Avatar
just wondering what the max compression for pump gas would be...maybe not the ragged edge but just a good high compression number.
Old Sep 29, 2003 | 09:30 AM
no one has an opinion on this?
Old Sep 29, 2003 | 10:14 AM
Nostang 96z's Avatar
I run 11.5-1 with pump gas. I think the max would be 12.5-1 but that would depend on the cam, plugs ,etc.
Matt
Old Sep 29, 2003 | 11:17 AM
what does the cam have to do with the compression?
Old Sep 29, 2003 | 11:32 AM
InjectedSS's Avatar
Bigger cam's tend to bleed off cyl pressure, hence allowing you to run higher compression's.
Either way I think 12.5:1 is the MOST I think you could go on the street with PUMP GAS. Even then that's pushing it.
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
